calewjohnson
Sep 24, 2015Explorer
Even with the genset or shore power, a good battery has to be installed. The Level-Up looks for a battery with good voltage. Thumbing through the screen (using the up/down arrows), there will be a page that has battery voltage, if less than 10.8 volts, your battery is shot.
Go here for your system info and troubleshooting: https://lci1.com/support-levelup
On a side note, unsure if you have Schwintek or cables on your slides, if Schwintek....never, ever, ever run the system with out the genset or shore power, or have more than one good, fully charged batter installed...
Also, welcome to your new Voltage...head over to the Dutchmen Owners, there is a dedicated TH section and the Voltage folks are pretty active with a lot of specific Voltage knowledge.
Cale
Cale
About Fifth Wheel Group
