centerline
Jan 09, 2018Explorer
check and see if the area where the air COMES IN to the housing is clear.
it may have sucked some debris or a piece of paper that is blocking the intake....
normally, if the air can get in to the fan/blower, it will find its way out.
also check the oil and the low oil shut down sensor.... we have had the low oil shutdown senders fail after they get warm.. you can simply unplug it to check it.
when the motor dies, unplug the low oil sensor and if it starts right up again, its a bad sensor.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
