RollandB
Nov 08, 2016Explorer
I thought I would chime in with a few things since you are in consideration for full timing in a few years. Our fifth wheel is an Arctic Fox 27-5L which is a similar floor plan to the Jayco 293RKDS. the length of ours is about 6' shorter than the Jayco. We moved from longer rear kitchen Komfort and was looking at a shorter length.
We really like the living room area on ours. For TV viewing is straight on instead of at an angle, with the corner kitchen layout, our trailer has a larger feeling compared to our previous rear kitchen. It's good having the fridge closer to the wheels for let's jostling around when traveling. We opted for a booth dinette instead of chairs and a table which works well for sleeping when we have grandkids along.
While ours is prepped for a generator, having a Honda 2000is portable we opted to not have one included. Instead, I installed solar and am about to install an inverter. When done will have spent about the same $$ but won't have the sound of a generator when boondocking except if we get to a shaded area or days of clouds.
Hope it helps even though ours isn't a Jayco. For full timing the bedroom in the Jayco is probably better in size, fwiw.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
