Lantley
Apr 17, 2017Nomad
53 willys wrote:
Well guys live and learn Keystone with this model trailer doesn't plumb it to a gray water tank , the dealer told my son in law to use a bucket or small portable gray water tank to drain into. It's only plumbed across to the other side of the trailer to a dump connection. Can you believe that ? I don't know if you all think this way but when I buy a RV I assume that the sink would drain into a holding tank. My son in law is a little upset with Keystone as he should be .
Most outside sinks are not plumbed into the tank. Typically there is not adequate fall/access to properly plumb into grey tank.
As you are learning do not assume they are plumbed into a grey tank.
My observation has been most are not connected to the grey tank
About Fifth Wheel Group
