dougrainer
May 26, 2022Nomad
Your model has the Schwintek Slide rack system in the front Bedroom. NOTHING about the Slide mechanism can be modified. Once you remove the Bed(brochure states the LARGEST bed is a Queen, no King option), there will be wires under the bed frame that will be exposed. Those wires go to the slide box overhead lighting. Depending on HOW Jayco built the system, there may also be the slide rack wiring exposed once you remove the bed. These things can be cleaned up and partially or totally hidden. BUT as noted by me, the slide box and Schwintek Rack slide out system, the mechanical cannot be modified at all. Under your existing bed, you can pull up the floor under the bed frame and also when retracted look at the area under the headboard to see those wires. Nobody at Jayco can tell you how to do this type modification because they NEVER do this type modification and OEM's NEVER give modification info due to liability. But it can be done and look good if done right. Doug
About Fifth Wheel Group
