Brutussr's avatar
Brutussr
225/75r15 down to a 205/75r15
This is the first time I have had to buy new tire and I was considering dropping one size from a 225/75r15 to a 205/75r15. Both are load range D tires. Total it would lower my trailer half an inch. Any thoughts ?
Thanks
Stephen
  • I was considering dropping one size from a 225/75r15 to a 205/75r15
    Actually that is 2 sizes. There is a 215/75R15 but it is not very common. I also agree with the others. Stay with the 225's as it will affect your capacity.
  • I would not recommend your suggested change. It will affect the GVWR of your trailer and may be unsafe. Even though both are Load Range "D", the larger tire has more max load capacity.
    I captured the following info from Tirerack.com regarding one of their ST tires*:
    P205/75R15 - Max Load 2150 Pounds
    P225/75R15 - Max Load 2540 Pounds
    You would lose 390 pounds of capacity per tire. That is 780 per axle, and 1,560 pounds on a tandem axle trailer.
    * Power King Towmax STR.
  • I went from 205 C's to 225 75 15 E's. No tire problems for the 7 years I ran them. I don't see a 1/2" lower as a benefit.
