deltabravo
Feb 12, 2015Nomad
1L243 wrote:
I am thinking that running two AC's on a 30amp or three on a 50amp system is going to require some kind of electrical management control. ie if your running all your AC's amd then flick on the Microwave or Coffee maker it's going to shut down one of the AC's till the load passes.
Xantrex makes a system that does exactly that, but your typical RV production line factory can't come close top comprehending how to install such a beast in an "assembly line" environment where everything is thrown together.
High end motor-coaches use them.
http://xantrex.com/power-products/default/freedom-sequence-ems-power-manager.aspx
Looks like it works in conjunction with their inverter - I don't know if t will run as a stand-alone load management system or not.
About Fifth Wheel Group
