gtsum
Feb 15, 2015Explorer
After looking at more units yesterday, we are going to order an XLR Thunderbolt 340x12hp. The floor plan has everything we are looking for and seems to be put together fairly well. I spoke with the factory rep about 2vs3 AC's and he said they do a few of them on the bigger AMP lineup (40ft plus) and it has an Energy Management system that allows you to run all 3 at the same time. If you then run water heater, or coffee pot, etc,it will reduce the amps (or whatever) to the garage one and would eventually shut if off if the draw got to be too much and start it up again when available. Said can run all three with the 5500 generator and when on 50amp power can run all three without issue or interference from the energy management system????
Seems like a good idea? Said he can only recall a few of the 340x12hp units being sold with the 3 ac's. Said arizona, florida, etc in the dead of summer you will need all 3....the bedroom ac is tied into the ductwork of the main ac, (ie not just blowing in the bedroom), so 2 would like be enough for our purposes (bedroom and living room)
About Fifth Wheel Group
