Johno02
Feb 16, 2014Explorer
As the wiring was probably installed for a 220v circuit, A copper ground back to the box may not be required. The white wire is always a ground, and codes may just require an earth ground at the outlet. I thing your best bet would be to check with a local licensed electrician, but I personally would never use a red wire as a ground connection.
About Fifth Wheel Group
