24rules
Feb 16, 2014Explorer
this is what I did I have worked as a electrician for 20 years.i would use the black and red as your 120 volt hots the white would be a neutral since some of higher tech high voltage appliances with all the integrated circuit panels need a neutral to work properly and then get a 8 ft. ground rod and drive it in the ground and the run a 10 bare or coated wire to the ground lug on your rv outlet or sub panel whichever you are using because in my area sub feed panels all need a isolated ground which you will create with the ground rod do this and you will be adequate for all the nec codes that I have dealt with
About Fifth Wheel Group
