Dutch_Oven_Man's avatar
Feb 16, 2014
30 AMP home wiring Question
The previous owners of our home installed a 8/3 wire from the breaker box to the garage. I assume they intended to install a welder or something, but never did. The wire terminates in the breaker box and is not hooked up to anything, and the wires are loose in the metal outlet box.
I was hoping to install a 50 amp service, but realized I don't have a ground wire. I have a red, white and black wire only.
My question is, can I use the red wire as my ground for a 30 amp service? I'm thinking I would connect my hot and neutral as usual to a 30 amp single pole, and the red to the ground buss bar in the breaker box.
I found several people on here refer to www.myrv.us that has very good instructions about wiring a 30 amp service, but it doesn't address my question.
