driller's avatar
driller
30 to 50 amp. Problem adapter/converter melting and failing
30 amp service to 50 amp RV. Problem with adapter/converter melting and failing. We have a 2011 CrossRoads Sahara Cruiser CF30ES with 50 amp service. Our last trailer was only 30 amp so that’s what I installed for service. My problem is my trailers 50 amp service is at the rear of the trailer and comes up 10' short of the service box. This requires a 30 amp RV cord to the 50 amp cord with the use of an adapter. My first adapter standard corded 18” failed, I was able to replace the outlet ends but it failed again. I replace with a different style without a cord and it didn’t last 2 months. What’s causing the failure is an additional ceramic safety heater during the winter and running a single AC during the summer. While running the RV’s factory electric fireplace furnace and the additional heater or the AC its drawing too much power for the adapter and causing the 30 amp female from the extra cord and the male end of the adapter to melt. Would an adapter like this https://www.etrailer.com/RV-Wiring/Camco/CAM55025.html solve my problem? As long I plug the 15 amp into a separate breaker!
