- NC_HaulerExplorerAnother vote for the B&W RVK3600 hitch if you have the puck prep package....easy install.. Ron and I ordered from Tweedy's on the same day:)
- SolidAxleDurangExplorer II
Me Again wrote:
Cummins12V98 wrote:
"Wiring Kit P/N 82212195 202B $96.85
Pucks P/N 82213665AB 221C $250.00"
When ordering a new RAM it's a no brainer on the towing pucks and 7 pin connector in the bed. My factory option cost me $340.
Plus you get the gooseneck hitch! But most dealers do not add this option for trucks they floor.
Chris
Every truck my dealer stocked had it. - Cummins12V98Explorer III
GBuilders wrote:
Cummins12V98, talked me into getting my B&W 3600 25K and it's so much better and smoother then my old Reese. I have never had an air hitch but I know the cost is much higher. The puck system is a huge win for Ram IMO as Its so easy to remove and store while not in use. It comes a part in two pieces for ease of removal. It is a heavy hitch.
Geese a couple more referrals and I will qualify for the personal Factory Tour. :B
I reluctantly listened to a good friend and installed the B&W TurnoverBall and companion in my 98 RAM in 05. I still thank him every time I see him. I was so sick of the constant rattling and metal popping sounds coming from my RBW hitch it was very unnerving.
As they say silence is golden! - Me_AgainExplorer III
Chris - Cummins12V98Explorer III"Wiring Kit P/N 82212195 202B $96.85
When ordering a new RAM it's a no brainer on the towing pucks and 7 pin connector in the bed. My factory option cost me $340. - tinner12002ExplorerB&W 25K, can tow about any size toy hauler I could purchase.
- GBuildersExplorerCummins12V98, talked me into getting my B&W 3600 25K and it's so much better and smoother then my old Reese. I have never had an air hitch but I know the cost is much higher. The puck system is a huge win for Ram IMO as Its so easy to remove and store while not in use. It comes a part in two pieces for ease of removal. It is a heavy hitch.
- retispcsiExplorerX2 B & W 3600 best non air hitch on market.
shepstone wrote:
Me Again wrote:
Which is the RVK3600 for the RAM with pucks! Best with long bed.
I did the RVK3270 manual slider and Demco 6099 picture frame.
Pucks can be added fairly easily to a lot truck that was not optioned with them. I did I myself in 4 hours including the 7 way outlet in the bed.
Chris
How difficult was it to get the outlet in the bed?
Drill the hole, four screws, and the pig tail plugs (T's) in at back side of the bumper pull outlet. This kit with a RAM Part number was in a Curt Box.
So getting the gooseneck part also with the factory option for 400 bucks is a better deal. If I ever need that I will most likely buy or have made a plate that pins into my picture frame.
Chris - shepstoneExplorer
Chris
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
