colebones's avatar
colebones
4 motorcycles 1 rv
So we are looking at getting out first toy hauler. Wanting something that could fit at least 2 street bikes (crotch rockets) and 2 dirt bikes. Wanting it to be a separate garage or kinda like a cy3418 maybe. Possible wanting a side patio as we have dogs? Pretty new any advice would be helpful really. We want to be in this thing full time.
  • im not the weight police but will tell you I first towed my smaller carbon with a 2011 f250 that was bagged and will never do that again! it had plenty of power but I now know how much better a dually is with a large 5th wheel.
    before you buy I would look at the door tag on your truck to see what that cargo capacity is, my 250 was only 1960lbs.
  • Our truck is a 05 2500 cummins single tire. I have a friend with a 44ft carbon that tows his with a 2500 duramax so I assumed we would be ok truck wise.
  • schlep1967 wrote:
    What you want is an RV pulling an enclosed trailer. You do not want to live full time with bikes, gas and oil in the residence.
    I'd say you've never owned a toy hauler correct?
    to the OP, you'll need a very large trailer (40') to get 4 bikes in the garage and be comfortable full timing. fitting in 4 dirt bikes shouldn't be hard but make two of those sport bikes with fairings, lights, etc. and you won't get 4 across, probably the two sport bikes straight in, the dirtbikes sideways in front or behind. 10' garage minimum I'd say.
    You'll need a big truck to pull it too
  • BTW, I could fit 2 sport bikes and 2 dirt bikes in my 12' garage assuming you are referring to normal size dirtbikes and not 2 bmw 1200 GS's.
  • ive never had an issue with gas smell in my rv, I close the door going into the garage and it is a separate area.
    You have a diesel, but is it enough truck to tow larger 5th wheels?
  • For what we wanna do the toyhauler is the only way don't wanna be lugging around a 35 ft rv on top of a 16 ft trailer. Plus we already have a cummins to tow with.As to the carbon 387. We wouldnt wanna tow it with a single tire truck? As that's what we have now.
    WHY NOT??
  • there a few to choose from with separate living areas, but you will be looking at a larger 5th wheel that most likely will require a dually truck to tow.
    keystone carbon 387 has a 17' garage
  • What you want is an RV pulling an enclosed trailer. You do not want to live full time with bikes, gas and oil in the residence.
  • Full timing with bikes and dogs, buy as large as you can.
    I can fit 3 full size dirt bikes and two 50cc minis in my small 23' TH but no way in heck I'd want to full time in it.
