Old-Biscuit
Jan 10, 2015Explorer III
TW (tare weight) 29-30# depending on cylinder.
It will be stamped on collar.
Holds 40# of propane....full tank ~70#
FYI
How much should the tank weigh?
38 lbs. for a full 20 lb. size propane tank, 18 lbs. if empty.
54 lbs. for a full 30 lb. size propane tank, 24 lbs. if empty.
70 lbs. for a full 40 lb. size propane tank, 29 lbs. if empty.
What size is my propane tank?
18 inches high and 12.5 inches diameter for a 20 lb. propane tank
24 inches high and 12.5 inches diameter for a 30 lb. propane tank
29 inches high and 12.5 inches in diameter for a 40 lb. propane tank
FYI
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
