Cloughfam's avatar
Cloughfam
50a to 30a question
Looking towards the future about going from a TT to a FW. One of the models I like the most comes standard with 50a service. Should that be a concern as 99% my wife and I camp where only 30a is available?
Not sure if its detrimental to the lifespan of the appliances, or if we just need to treat it like we currently do and turn off the AC if we need to run the microwave.
Thanks for any help clearing this up for me.
Mike
  • Cloughfam wrote:
    ....., or if we just need to treat it like we currently do and turn off the AC if we need to run the microwave.
    Yes.
    Although if you run the fridge and water on propane you can probably run the microwave at the same time the air is running.
  • Plus per Me Again link I have the remote located inside where it's easy to check when needed. Another neutral problem is the power cord neutral or the CG pedestal neutral as the plugs get worn out.
    Be aware that a open neutral on 50A is significantly "worst" than on 30A.
  • Give serious consideration to installing a EMS to protect against low voltage with is rather common in 30A CGs. I recommend the PI HW50C which also protects against other faults. Don't leave home without it.
  • You still should install a 50 surge protector. I did the hardwired one in zoo/dungeon.
    This is the one I installed.
    https://www.amazon.com/Progressive-Industries-Hardwired-Electrical-Protection/dp/B003AN1UA8/ref=pd_cp_263_1?_encoding=UTF8&pd_rd_i=B003AN1UA8&pd_rd_r=93f8e1a6-5cfe-11e8-85e9-dbae31ccb6d1&pd_rd_w=uoLlK&pd_rd_wg=18Wss&pf_rd_i=desktop-dp-sims&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=80460301815383741&pf_rd_r=5DX7RV2E8K8FBWWDXWHK&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&psc=1&refRID=5DX7RV2E8K8FBWWDXWHK
    While on a 50 amp outlet, if you loose neutral you burn up all your AC items with 240V across them. I did the hardwired one because it protects me from a problem with the powered cord reel for the shore power cable. And it is not going to grow legs.
    I would also note that while powering the trailer for dry camping with our Honda eu2000i generator, I have to put a male cord cap with neutral and ground bused together in the generator second outlet for the surge protector switch the power on.
  • The rig is designed to use more power. Multiple A/Cs, HW, MW, etc and you may want to push that additional button but can't - The 30A pedestal CB will trip.
    I added an additional circuit with 2 plugs mostly for ceramic heaters. For 50A pedestal it plugs into an existing basement outlet. For 30A I run an extension cord to the pedestal (most have 30A and 20A outlets). Others have modified a AC power wires so it can be run off of the extension cord. By all means use a heavy extension cord and not the typical home cord.
    If you are not aware 50A is 240/120V 4 wire. In RV speak this simply means you have two 50A 120V circuits for the rig or as some like to say 100A available vs the 30A pedestal.
  • BarneyS wrote:
    Use the adapter and treat it just as you would a 30amp unit. Won't hurt a thing in the RV. If you try to run too much you will just blow a breaker just like your existing unit.
    Barney
    X2
  • Use the adapter and treat it just as you would a 30amp unit. Won't hurt a thing in the RV. If you try to run too much you will just blow a breaker just like your existing unit.
    Barney
