fly-boy wrote:
It sounds like a really poorly designed trailer- it makes no sense that you have a TH and can't load toys and pull comfortably down the road.
Maybe a band aid but I would still add water capacity- which is very easy to do. Also, I would try loading the toys in the reverse fashion, move batteries, etc.
If I had to move axles to make a trailer right I would send it down the road and buy something else.
Based on the intel; i'm guessing that his issue is that with the rzr he is forced to have most of the weight behind the axle (because the rzr can't sit next to the raptor). So he is in a pin light situation when loaded. Not sure if its a poorly designed trailer; likely a side effect of the side x side's getting popular and pushing weight to the rear.
I wonder if loading the raptor sideways in front of the rzr would work?
