TWO_4_THE_ROAD's avatar
Aug 19, 2015
5ER FRONT MOULDING
The front panel keeps separating from the side panel on my 5er. It has a thin moulding but with the movement and flexing, it comes apart. I'm looking for some kind of flexible moulding that can replace. Any ideas?
  • I have similar problems, along with body screws coming loose and falling out.
  • donn0128 wrote:
    You likely have a frame failure. Lippert had a lot of frame flex issues during that time frame. I suspect if you were to open things up you will find cracked broken welds and possibly some other structual issues.
    I would bet money on structural problem.I had a Rockwood almost the same model with the same problem.The fix was very extensive.
  • You likely have a frame failure. Lippert had a lot of frame flex issues during that time frame. I suspect if you were to open things up you will find cracked broken welds and possibly some other structual issues.
