Xflyhighx wrote:
Hello Cummins, what is your measurements from the ground to the middle of the pin? What hole do you think I need to put the hitch in? How much air do you have In your trail air
I don't know pin height, sorry. I have B&W set to lowest height and full forward.
I run 100# in mine but I can tell you even if I did not have the air bag I would not have any CHUCKING. If you had no bag with your hitch you would have chucking. Bag has nothing to do with chucking.
All you can do is have at least 6" bed clearance and the "PROPER" air pressure is based on the tip of arrows being even with outer sleeve on shock.
LOWER your rear tires to 5psi over what the load/inflation chart says. Won't help chucking but will help with the ride quality. It may help with what starts the shucking to happen.
Top back corner of my bed in alt ride height is 55" loaded or not. Bed to top of hitch 17" and about 3" below top of bed.
I know it's not what you want to hear but as others have mentioned it's the hitch since it's pivot point of the head allows for fore and aft movement causing the chucking.
