I thought I was on top of things doing all the weight calculations and bought a truck and 5th wheel. I pick it up next weekend. I came to realize that I messed up as I only included the dry hitch weig...
I don't think you are going to be over weight, but the scales will tell the story. You don't want to take away too much pin weight by adjusting the load. You want to keep 20 percent of total wt on the pin.
You likely wouldn't need the heavy slider hitch, but should still work.
You should be able to put near 2800 lbs over your rear axle, and still be within RAWR/tire max.
