mighty7sd
Jan 06, 2017Explorer
5er Loading
I thought I was on top of things doing all the weight calculations and bought a truck and 5th wheel. I pick it up next weekend. I came to realize that I messed up as I only included the dry hitch weig...
jshupe wrote:
Don't load it that way, you don't want to pull too much weight off the pin. You're safe going up to your RAWR on that truck and will be fine. Going off of GVWR numbers, 90pct of 3/4 ton trucks with 5'ers are overloaded.
