mighty7sd
Jan 06, 2017Explorer
5er Loading
I thought I was on top of things doing all the weight calculations and bought a truck and 5th wheel. I pick it up next weekend. I came to realize that I messed up as I only included the dry hitch weig...
jshupe wrote:The_Painting_Teacher wrote:2oldman wrote:
Yes, adding weight behind the wheels will lower the pin weight...but obviously adds to your total towing weight.
Just curious .. how does putting weight behind the axles add to towing weight? Not trying to be part of the irritating weight police; I am truly trying to become informed. Isn't weight towed constant regardless of where it is located?
I assume he's referring to adding weight via additional contents that would ordinarily not be towed, eg: extra water in the freshwater tank, plate steel for the purpose of ballast only, etc.
