Magnum164's avatar
Magnum164
5th adapter
My truck has a b&h gooseneck already installed. I want to get a large 5th wheel and wondered if the b&h 5th wheel adapter would be limiting. Its listed at 18k lbs.
Has anyone had any issues with this unit or should I bite the bullet and just get a solid unit.
  • Alley Fox wrote:
    Been using a B&W for years with no problems, it is very strong and quiet, as far as I'm concerned it is the best 5th hitch made.
    Thanks. Only problem now is to unstick the turnover ball and get a new one. Just a little rusted for me.
  • Bird Freak wrote:
    Ok, I was just wondering if I missed something with the other post talking about what your 5er weighed. Guess they didn't read post instead of me.
    Correct. Hitch rating not actual weight.
  • Been using a B&W for years with no problems, it is very strong and quiet, as far as I'm concerned it is the best 5th hitch made.
  • Ok, I was just wondering if I missed something with the other post talking about what your 5er weighed. Guess they didn't read post instead of me.
  • I have looked at a few 5ers but have not been looking at weight. Will start looking when I check the ads.
  • An 18klb 5'er is a big one. Your getting into custom territory there. Some toyhaulers max out in the 21-22 range but they need to be towed with an MDT
  • Yes. I have a dually. Probably will not need that much but want to make sure I am not limiting myself. Did not notice they have a 30k.
  • If you are referring to the B&W Companion Hitch then it should be fine if it's rated at over 18K. I see they have one rated at 30K (RVK3000) so it should be OK. You still nee four holes in the truck bed.
    That's a really heavy 5Ver do you have a dual wheel truck?
    BK
