Second_Chance
Jan 06, 2020Explorer II
I have experience with it. All the Correct Track system will do is allow you to make sure the axles are parallel with each other and perpendicular to the center-line of the trailer. The system can do nothing about caster, camber or toe. If you have a bent axle or spindle, the only solution is either bending the axle or replacing the axle/spindle unit.
Rob
Rob
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 22, 2026
