- miataredExplorerI've been using dual 6V Costco GC batteries and am VERY happy. They also have a very good warranty. Going on 4 years now and still very strong.
Big Thumbs Up! - GoPackGoExplorerI think Costco may be selling Interstate batteries now. Not sure.
- MrVanExplorerHow a bout the 6V golf cart batteries that Costco sells?
- bpoundsNomadIt is true that there are only a very few battery manufacturers left in the US. And EPA is doing their best to drive them out of business.
Having said that, I don't know why people assume the batteries must be the same with different labels. It is obvious to me they are not. They will build a battery to any price point you want, if you distribute enough of them. - laknoxNomadI replaced my 2 12v batteries with 2 6v golf cart (true deep cycle) batteries from Sam's Club. I'm very happy with them and can dry camp for almost 5 days with a bit of help from a 45w solar charger.
Lyle - CampinfanExplorer IIIGot a Duracell from Sams Club for two different vehicles this year. Bth have been great and had good ratings.
- AllworthExplorer IISince we travel FHU to FHU and the only place I could find late one evening in rural South Carolina was a Wal Mart; we have been using a WM marine deep-cycle battery for three years and it shows no sign of weakening.
- AZ_T_TExplorer
GASMAN6674 wrote:
I have had good luck with Interstate (so far)
Put me down for an Interstate user. - GoPackGoExplorerB.O. Plenty is exactly right. There are only a couple manufacturers. Johnson Controls is one of them and they make a lot of batteries that are sold under several different brands. I believe they used to make the Sears Diehard batteries.
Most important - Don't get a 'starting battery'. Preferably, get a Deep Cycle battery. But what you will mostly find are 12 volt RV/Marine combination deep cycle/starting batteries. Just don't get a battery that is strictly a starting battery. And get the largest one that will fit in the battery box.
If you have 2 boxes, then you could get 2 12-volt batteries and hook them together in parallel, or 2 6-volt batteries (golf cart batteries) and hook them in series. The 6 volt batteries will work best and last longer because they are true deep cycle batteries, meaning they can be discharged to a 50% level and then recharged without damage many times, compared to the 12-volt combo battery options. Making a habit of discharging a starting battery to the 50% level before recharging will shorten it's life drastically. You can get 6 volt batteries for around $80-85 each at Sams or Costco.
Tim - bpoundsNomadDepends on how much you depend on the battery. If all you care about is enough to operate for a few minutes between FHU campgrounds, just get whatever is cheap. If you want to boondock off the grid, you're going to need to upgrade the system.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
