cKarlGo wrote:
brirene wrote:
Put on and take off by myself.
How do you do that? I've never quite been able to puzzle out the mechanics of such a project.
Fold it into thirds and roll up back to front. Grab onto the front section and climb the ladder, allowing the cover to unroll on the ground. Drag cover to front, across the middle of the trailer,.then drop each side down. You'll of course need to make a few adjustments, but it works pretty well. Need to make sure its oriented correctly so that its not upside down when you get on top. To remove, I've found the easiest to be simply pull one side up to the top and drop it over the other side. Orient correctly, fold into thirds, roll up tightly (back to front) and store in a large garbage can. Mine included a dvd with essentially this information.
To OP: wind its your enemy, with this or any cover, and may even damage your unit. My location is very protected from wind, and is no doubt why my cover has lasted so long.
