- Cummins12V98Explorer IIIFTG you won’t need the flashlight unless it’s dark. The silver jaws are easy to see.
laknox wrote:
Cummins12V98 wrote:
Well I challenge anyone to show proof of a dropped trailer using a B&W hitch that the pin box plate is touching the hitch plate, the 1" thick machined jaws are closed around kingpin and handle is closed pinned to locked.
I am waiting.
One BIGGIE to NOT do with a B&W is pin the handle open!!!!!!!
I threw my pin away and use a padlock.
Wanna see =my= pics? :-) Not the hitch's fault; totally =my= fault that I dropped my FW off my Companion. What happens when you get in a hurry and skip your checklist... :-(
Lyle
You did NOT do what I mentioned. - Cummins12V98Explorer III
azdryheat wrote:
Cummins12V98 wrote:
As long as we're talking hitches I notice you have the Trailair TriGlide pin. I had one on my toyhauler and 2 of the 3 rollers on the bottom broke their welds. The trailer would bang back and forth on starts and stops. The rollers are inside where those three zerx fittings are. The remaining roller was all that was keeping the trailer attached to the truck. TriGlides arean't made anymore. I got a new Trailair hitch without the bottome TriGlide portion. Keep an eye on yours for any failures.
I am waiting.
I appreciate the heads up!!!
I do grease ALL 9 ZERKS often with AMZ/OIL.
Mine is rated at 21k. My RV weighs 24k and then add for MC and trailer when double towing.
5 years and all is well. Must have gotten a good one. ;) larry barnhart wrote:
The couple now drive a 450 ford.
chevman PS he seems to be not very experienced on things that move. Not meaning the new truck as that was a great idea to do for them.
chevman
2 different guys.... The guy narrating the video with the F450 is NOT the guy who dropped the fiver on hid truck.....
I have watched a few of the BigTruck/BigRv YouTube videos.... Some are interesting... some are not.. HE has the 450
I saw the guy drive his new f-450 and saw the 06 chev being driven to the ford's lot. chevman
Yes, I ws unaware of that ... another poster advised me... thank You...Cummins12V98 wrote:
cummins2014 wrote:
Dave H M wrote:
Lot of hoop a laa. Kinda of an expensive commercial?
I do not do a pull test but do check the jaws on my Reese classic. I also have one of those Butch's Services bars that slides in behind the king pin.
You went ,and done it now, you know full well the only ones that don't have to do a pull test is the B&W crowd, with their FOOLPROOF hitch . :B
Well... I will say this.... I drove Big Trucks for over 35 years and was pounded in my head to perform a pull test early on... Never left without doing one... caught 1 potential issue when the hitch failed....
Did one with my Pullrite.... Will do one with my new B&W... It's branded in my memory.....
You SHOULD do what works for YOU. But I still Highly advise doing the VISUAL test as shown in pics above.
I keep a small AAA Maglight in my side door compartment, Once hooked up, while plugging in the electric, shine it around the jaws.... Been using that for many, many years- cummins2014Explorer
Yep, they're foolproof, but NOT idiot proof, as I can attest.
Lyle
You can't fix stupid, and as long as people use these hitches, IMO they should give themselves every chance to prevent a mistake . Granted some should not be towing these big heavy fifth wheels, and for sure not be hearing a visual test is all thats needed. - larry_barnhartExplorerI will do maybe my last pull test when we can hit the road in May or early June because I just feel better doing it. Lock my hitch also. chevman
chevman
I saw the guy drive his new f-450 and saw the 06 chev being driven to the ford's lot. chevman - Jim2007Explorer
DickOK wrote:
Hi Dickok, yes, the green is not showing and the jaws are not locked. I then pull ahead and they lock up and no further problems . I am just puzzled as why the jaws do not lock up when I back in. They had been locking up on back in for 3 and half years. Maybe a part is wore out. Jim2007.
Just got a new Curt hitch when got new truck. Did you check to see if green was showing? I always have done a pull test for 15 yea
rs. - laknoxNomad
Lyle
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
