stus__family's avatar
stus__family
5th wheel height
I'm thinking of going from a travel trailer to a 5th wheel. Probably a Cougar or Wildcat.
Both list the height at 13'2". I will tow with a 2018 Ram 2500 4X4 using a Trailer Saver BD1 hitch.
Can anyone tell me if my heigth will be greater than the listed height in their brochures and if so how much.
I have a 12' door on my garage and would like to know what I need to do to store the 5th wheel inside.
The trusses in the garage are 14' from the floor so I don't think that will be a problem once I know what to do about the door.
  • Door is in the gable end of a truss roof garage. There is no load bearing header above the door and I have had a door company look it over. There are options such as special order 13 1/2' door and close mounting hardware.
    My question was how much height do I need to add to the brochure listed height when I hitch my trailer in the high 2500 Ram. My bed rails are 5' off of the ground so it seems to me the trailer will sit nose high.
    Hopefully there is a 2018 Ram 2500 owner out there who can answer my question.
  • You will need sliding doors on the outside to get the full 14' opening
  • What mat60 said. no bueno for getting your trailer in the garage.
  • I would talk to a garage door company but Im wondering how they could get a 14ft door in because of room needed for the overhead hardware. You may also have a load bearing header above your existing door. I have the same kind problem with my shop.
