- Retired_JSOExplorer IINot sure why Ram an GM doesn’t give this info.
2021 Ford
F-150 58.3”
F-250 4x2 57.8”, 4X4 60.0”
F-350 SRW 4X2, 56.7”, 4X4 59.7”
F-350 DRW 4X2 58.1”, 4X4 58.9”
F-450 DRW 4X2 58.8”, 4x4 59.3”
*Raptor 5th-wheel towing is not recommended.
**Distance from ground to top of closed tailgate lip at base curb weight.
Note: Maximum tailgate height will vary based upon vehicle configuration, option content and tire size - Cummins12V98Explorer III
cummins2014 wrote:
Cummins12V98 wrote:
cummins2014 wrote:
Cummins12V98 wrote:
Many 2 and 4wd trucks ride the same height in the rear especially the newer ones.
Yup, just had a gentlemen PM me on the Andersen hitch , has a 2018 Ram 3500 2 wheel dr SRW , top of the tailgate is 59.5" nearly the same as my 2014 .
That is what's so nice about the Rear air Ride on the 3500 RAM's it keeps the loaded and unloaded bed height at 55" top of tailgate.
Well that right there would make me change my mind about Rear air ride , 55" would be perfect , might even have to raise the hitch to get level .
Six years and 83k later it's been 100% trouble free. - cummins2014Explorer
Well that right there would make me change my mind about Rear air ride , 55" would be perfect , might even have to raise the hitch to get level . - Cummins12V98Explorer III
That is what's so nice about the Rear air Ride on the 3500 RAM's it keeps the loaded and unloaded bed height at 55" top of tailgate. - cummins2014Explorer
ford truck guy wrote:
Likes to tow wrote:
mileshuff wrote:
I have a 2007 4x4 Ram and it is the perfect height for my 2014 Winnebago fifth wheel. I do have a Superglide hitch which I believe is a bit higher than most others. If I ever replace this truck I have no idea what to do as so many point out the new 4x4 trucks are too high and I use 4wd.
Ford supposedly lowered their 4WD trucks some in 2020 but I still found them too high for my 31 ft 5th wheel
My 2020 F350 is exactly 2" lower than my 2016 F350 at the tailgate
Lucky guy ,I wish this 2014 Ram was the same height as my old 99 Superduty . :) - cummins2014Explorer
Yup, just had a gentlemen PM me on the Andersen hitch , has a 2018 Ram 3500 2 wheel dr SRW , top of the tailgate is 59.5" nearly the same as my 2014 . Likes to tow wrote:
My 2020 F350 is exactly 2" lower than my 2016 F350 at the tailgatemileshuff wrote:
Ford supposedly lowered their 4WD trucks some in 2020 but I still found them too high for my 31 ft 5th wheel- Since I do not need 4WD I did opt for the electronic rear locker differential on my new F250. My old Dodge had a limited slip differential and I think sometimes that did not work as the truck got old. Those clutches must wear out eventually. The electic locker hopefully will always be there when I need it.
- mileshuffExplorerI have a 2007 4x4 Ram and it is the perfect height for my 2014 Winnebago fifth wheel. I do have a Superglide hitch which I believe is a bit higher than most others. If I ever replace this truck I have no idea what to do as so many point out the new 4x4 trucks are too high and I use 4wd.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
