SUMRX4's avatar
SUMRX4
5th wheel hitch height
If I wanted to lower the front end of my 5th wheel, which would be preferred, lower the hitch in the bed or raise the kingpin on the trailer or does it even matter? If thinking lowering the hitch in the bed would put the kingpin lower and closer to the center of gravity of the truck. But them again would this even make a difference? I'm only speaking of about 2" that I need to move it.
  • RCMAN46 wrote:
    If you lower the hitch make sure you have clearance between pin box and the side rails on the truck in a tight turn.
    Correct!!!
  • If you lower the hitch make sure you have clearance between pin box and the side rails on the truck in a tight turn.
  • Lowering the B&W is easy so that would be the first step. Next would be to raise the kingpin.
  • I'm running a B & W companion and yeah it looks pretty easy to do so.
  • fj12ryder wrote:
    Personally, I would lower the hitch, since on a B&W hitch it's the easiest way to do it. Don't know what kind of hitch you have so can't say about yours. As long as you maintain the clearance between the bed rails and the bottom of your trailer, it's pretty much up to you.
    Concur
  • Personally, I would lower the hitch, since on a B&W hitch it's the easiest way to do it. Don't know what kind of hitch you have so can't say about yours. As long as you maintain the clearance between the bed rails and the bottom of your trailer, it's pretty much up to you.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
