Cummins12V98
Aug 10, 2014Explorer III
mackyb wrote:
Cummins - My truck is maxed out for sure. I have checked weights at the Cat scales recently and am right at my limits if lightly loaded but most of the time I am probably 500 lds +/- heavy (depending on how much water & gas I carry). I have never tried hitching up w/o at least 30 psi in the bags so I don't know what the truck looks like w/o the bags inflated. It seems like between the air bags inflated to 40 psi, the Trail Air pin box bag inflated to the proper setting, and the 20" wheels on the truck, I am going to be nose high unless some type of lift is done to the trailer. With that said, the truck tows the the FW real nice. I am not new to towing a trailer but I am relatively new to towing a FW, so any suggestions are appreciated.
Are you setting the bags to 30/40# with or without RV attached? The pressure setting should be done after hooking up the RV. My bags set at 5# empty increase to 30# with my RV attached.
When hooked up does the truck's rear sit higher than the front?
Do you have more than 6" space between the bed and RV?
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
