Cummins12V98 wrote:
laknox wrote:
Or, get a B&W Companion hitch that can still be released with a =lot= of tension on the king pin...if you're brave enough. :-O I chock the FW (not "chalk"), put the truck in neutral, then set the parking brake. Unpin the locking handle and move it to the open position and pin in in place. Sometimes, it takes a bit of effort, but it's usually (in my case) due more to =side= stresses from uneven ground than anything else. YMMV... Needless to say, I love my Companion.
Lyle
Just remember to pull that PIN from the locked open position. Only B&W hitch drop I have heard of and have WITNESSED both people had their handle locked open.
"IF" they would have done a "visual test" to see the handle was closed/locked, kingpin and hitch plate touching and 1" thick jaws fully wrapped around the kingpin neither would have dropped their 5er!
After unhooking, I always close and pin the handle. When hitching, I unpin and open the handle to the "hitch position", NOT PINNED OPEN, so the handle will swing shut as the pin hits the jaws. Occasionally, especially on uneven ground, I'll have to put some pressure in the handle to get it to close fully, but rarely. Pin it closed, jump down and do a visual check on the jaws. Even if I =did= leave the handle pinned open, my first action after backing into the pin is to get out, jump up on the tire and close the handle, so I'd catch it there. This is one thing that I do not let myself get distracted doing, to the point where the DW has got a "shut the f up and don't distract me".
Lyle
