OffTheRoadAgain's avatar
May 11, 2013
5th wheel hitch that attaches to gooseneck ball?
I recently got a killer deal on an F250 to pull the 5er that I'm buying soon but I've run into a snag and could use some advice. The truck has a gooseneck hitch in the bed. Not a Companion turnover ball; rather, a little plate that the hitch ball rotates down into. It looks a lot like this:
Am I correct that this will prevent the use of a Companion 5th wheel hitch because it's not a Companion turnover ball? Or will that hitch work with any gooseneck ball?
If not, are there any other gooseneck-ball-to-5th-wheel hitches? For many reasons, I'd like to avoid hooking the RV itself up to the gooseneck ball with an adapter on the kingpin. Am I going to be stuck removing the gooseneck hitch and its frame mount so I can install conventional 5th wheel rails?
Thanks for your advice.
