Rob_Fla's avatar
Rob_Fla
5th Wheel Hitch
I have been thinking about moving to a heaver rated 5th Wheel Hitch.
We currently have a 16k Husky Hitch in our 3500 GMC DRW pulling our Jayco Pinnacle.
Our Pinnacle weights about 15,400 lbs. loaded with a pin weight of about 3,500 lbs.
The Husky hitch is now 8 years old, been used a lot and still works good but been thinking about moving up to a heaver rated hitch.
Do not want to have a hitch failure on the road as many miles as we tow these days (about 12,000 to 15,000 miles a year)
We may go to a heaver 5er in the future so if I upgrade I want to be covered.
Our 2012 GMC 35000 DRW is 5th Wheel rated at 23,500 lbs.
What Brand / Model 5th Wheel hitches are the best in the 23K to 24K range.
1 Reply
  • If you've been happy with the Husky, why not getting another Husky with the higher weight rating? You have quite a few to choose from...you can probably use your original rails that the 16K Husky is mounted on to go to a higher rating Husky or Reese or several others, unless you're wanting to go a completely different route as far as hitches go....
