TGPILOT's avatar
TGPILOT
5th wheel Keystone 2007 Copper Canyon frustrations
Ok, getting a bit frustrated with this thing. Bought it used last Fall and dumped a ton of money that I wasn't expecting into it.
Started my three month vacation yesterday and after I got to Coburg, OR. I went into the Camping World they have there, to have them install three slide toppers they had on sale. While there, I brought up the fact that my slides were stalling when running them in or out. They found that some idiot had put a light wire on it, so they replaced it with a heavier wire that so far seems to do the trick. They recommended also, a 90 amp resettable fuse to replace the 30 amp that was on it. That they did not have will pick it up tomorrow at a parts house.
The other two issues were I had pop a couple of 30 amp inline fuses on the landing gear. Today, I blew two in five minutes. Don't have a clue to the problem here.
Last, when I had the rig in the shop all winter being worked on, I had them replace the old analog ant for a new digital one. Nothing, nada, not a pix on either TV, and yes I found and turned on the amp switch. Now, when I did a trial run on Memorial day I hooked up to park cable and got a bit off their messed up signal. I have one that says Sat. prep and the other is just a line in which I assume is the direct on air line. I've tried both.
Anybody have an answer to any of my issues?
Thanks,
Tom
  • I would not allow them to replace a 30 amp fuse with a 90 amp fuse unless they guaranteed me (in writing) that they verified that all associated wiring is sized to handle 90 amps.
    Slides starting/stopping during extend/retract are frequently due to a failing auto reset circuit breaker.
  • Are you running the landing gear up till the fuse blows? Easy fix is to add a reversing relay and rewire everything to work correctly,add some up limit switches. No more problems there. As for OTA TV? Never once in 30 years have I used it so outta luck there.
