Thank you for the link and the info. It does sound like a good alignment bonus but I had forgotten that we don't have axles. We have IS suspension so this won't work for us.
Our brand new 2014 2 wheel drive Ram sits as high as a 4 wheel drive giving us only 5" of clearance at the bed of the truck which is not enough. Dutch is investigating the different bolt patterns on our Mor/Ryde IS which would allow us to raise it, but according to Mor/Ryde gain only 1". He is also investigating another way to gain more clearance by using steel tubing between the chassis and the IS. That should give us 2inches or more of clearance. This would be very extensive and expensive work.
Has anyone out there done anything other than these 2 options? If so, what did you do? We have a triple axle Carriage
We had to leave Montana to beat the snow & cold so until we can get this taken care of, we are making sure we are on as level ground as possible when we make a turn.
Any suggestions will be appreciated. Di
