- magic43ExplorerI throw a pair of rubber chocks between the wheels on each side before I unhitch. After leveling, the JT Strongarms are tightened, and lastly, the X-Chocks are tightened between the tires. The only thing that "rocks" is us!
- larry_barnhartExplorerWe have had a great solid setup for several years. I installed scissor jacks in front of the front tires. This helped the spring bounce as I walked in the fifth and my wife was doing needle work. later the JT's came on the rv scene and they are so great for a solid feel. I made wheel chocks but some times I only use one. Wintering for 6 months the JT's help for a windy day or night. This was a surprise so we have everything we need.
chevman - Dutch___DiExplorerWe've had our stabilizers on for about 9 years and they really helped. We added the BF in 2010 and thought we might be able to do away with stabilizers but it didn't take long to realize that the BF will offer a bit of stability, it's job is to level. So with the ease of the BF and stabilizers we are perfect. Being fulltimers for 20+ years means we're in our rig 24/7 so no movement is a "biggie" to us. Hugs, Di
- rhagfoExplorer III
greende wrote:
Cheapest is BAL X-Chocks between wheels to stop suspension from moving.
Next would be stabilizers like JT Strongarms or such to stop stabilizer jacks from moving.
Most expensive would be a four point leveling system (aftermarket) to lift/stabilize frame.
Forget the X-Chocks and put on a set of JT Strong Arms!
We just finished setting up yesterday and we are rock solid with standard wheel chocks and the JT's! - Retired_JSOExplorer IIi
- Retired_JSOExplorer IIThis is his floor plan. If he cannot reverse the door, he still should have enough room for a towel or magazine to keep it cracked. I cant imagine the fridge would rub against that island going down the road.
- Dan_HenryExplorerWe have an Excel with the 4 point hyd leveling system. I made some blocks to put under the jacks about 6 inches tall in front the 7 1/2 at the back and this has helped. The more the jacks are extended the more the wiggle.
Dan - Allreds_Fifth_WExplorerhttp://rvpartsoverstock.com/product/x-chock-wheel-stabilizer-pair-one-handle/
Best pricing I have seen. - boatms03Explorerwill the JT'S work with the lippert 6 point leveling system?
- ipeltierExplorer"I have a jayco 28.5 rsts 5th and installed the JT's ,best decision ever. The only issue I had was having to relocate the spare mounted under the front as it was in the way of mounting brackets."
This is the model we have. We'll look into the JT's. Where did you mount the spare tire? In the back?
About Fifth Wheel Group
