- JAC1982Explorerx4 on the tree limbs. We've only taken our new rig out once and already got scratched... not while parking, but while trying to leave... one pesky branch at the end of the pull-through spot we had. I ended up taking a dog leash and "lassoing" the branch to pull it down out of the way so the husband could continue pulling the trailer away.
We've bought a set of tree-trimmers to keep in the trailer since then. - ^^^ X4 ^^^
- otrfunExplorer II
joebedford wrote:
x3. Especially if you're forced to pull into a state or any RV park with trees in the dark of night with no moon. Headlights are worthless for avoiding tree limbs right in front of you at 5-10 mph. We use a 700 lumen flashlight to light 'em up.lawnspecialties wrote:
The only thing I ever have an issue with is a low hanging limb at a state park somewhere.
^^X2^^ - joebedfordNomad III
^^X2^^ - stickdogExplorer
50,000 towing same problem just took out the AREO vent cover. - dedmistonModeratorI'm taller than some of the gas station canopies. I caused quite a stir in the little town of Panguitch, UT when I pulled into their biggest gas station. The lights on the canopy were lower than my AC units. I had to back out of the station when I was done tanking up.
- lawnspecialtiesExplorerThe only thing I ever have an issue with is a low hanging limb at a state park somewhere.
- arhayesExplorerWe're in a 42' TH and 13'5" at the front and 13'4" sat the back. If you go where 19 wheelers go you never have a problem. We do use an RV GPS which alerts if height concerns on route and there are many apps avbl as well. Just make sure you're watching ahead. In 3 years and 25,000 miles, we've never had to turn around or had damage because of height.
- BedlamModeratorMy current truck camper sits over 13' and my previous one was just under 12.5'. There are secondary roads with underpasses and bridges you will not be able to travel. If in doubt, stop and scout the area before proceeding. In Spokane, there are railway bridges in town with less than 10' of clearance. Look for truck routes when traveling and get an accurate real height of your rig in case you need to measure clearance - I carry a tape measure just in case.
About Fifth Wheel Group
