Nomad
Jan 17, 2020Explorer
5th wheel tires
What are considered the best tire for 5th wheels today
Have a Cedar Creek weighing 11,700 wet and it is time for a change
Curly2001 wrote:
The Endurance tires I purchased from Discount came with the advice from Discount to run them at MAX pressure all the time for the best towing/tire results. The trailer came with China bombs which did blow up, I tried Carlisle which one blew apart, and now have Endurance which so far, have done fine in the Arizona heat. Last year came through Phoenix at 112 degrees with my fingers crossed, checking my tire monitors and did make it to Tucson with no problems.
Curly
azdryheat wrote:
Any tire from China is junk, no other way to describe them.
83trekker wrote:
I am replacing mine this year, my axle is slightly off as it burned 2 of the tires off, but i did take 7 years for it to happen. Called our largest axle place here and to re align it its the cost of a new axle. I am not going to bother fixing it. The way it wears the tires down, by the time they are worn down its time to replace the tires anyways.
pcm1959 wrote:Cummins12V98 wrote:
If you are running full 110 inflation on a rig that only needs 80 it is overkill.
If airing based on weight carry on.
If I recall, GY says to run a tire at max speed rating it must be run at max sidewall pressure. Yes???
