Nomad
Jan 17, 2020Explorer
5th wheel tires
What are considered the best tire for 5th wheels today
Have a Cedar Creek weighing 11,700 wet and it is time for a change
cummins2014 wrote:Cummins12V98 wrote:
"So according to YOU, and that inflation chart, I should be inflating those G rated tires at about 70 psi."
YEP, Add 5 psi to the chart.
No I am not the only person doing so.
My Avion had GY "E" tires inflated to 80psi. Changed toy to GY "G" because there were no acceptable US Made "E" tires at that time so I went to the GY "G" tires and the chart said 80 so i ran them at 85psi. Ran this for several years and thousands of miles with perfect tread wear and NEVER hot.
Charts are there for a reason.
It just seems you are the only one promoting it, but if you say so.
joebedford wrote:
I was surprised to see in this thread that Bridgestone has discontinued the R250. I have 6 of those on my TH. They've aged out. Thinking of replacing them with Sailun S637. What's the best place to by them? I'm in Florida.
JIMNLIN wrote:
Most folks understand ply sheer stress with tires on trailer with close spaced axles.
And most folks can read all the website info on why max sidewall pressures work best for tires on a trailer.
And most folks understand those load pressure charts are a minimum pressure for that load only with no reserve that hi scrub tires on a trailer needs unlike low scrub tires on the tow vehicle.
For those that don't understand the need and reasons for higher pressures on any tire on a trailer should spend some time on Tireman9 rvtiresafety.net website. You get input from a actual tire engineer who understands why max pressures are recommended. Its suggested reading for those interested in knowing the howz and whyz. http://www.rvtiresafety.net/2019/07/why-inflate-motorhome-tires-differently.html
This clicky is one on several Tireman9 has on the subject on pressures for tires on a trailer. Lots of reading.
Cummins12V98 wrote:Curly2001 wrote:
The Endurance tires I purchased from Discount came with the advice from Discount to run them at MAX pressure all the time for the best towing/tire results. The trailer came with China bombs which did blow up, I tried Carlisle which one blew apart, and now have Endurance which so far, have done fine in the Arizona heat. Last year came through Phoenix at 112 degrees with my fingers crossed, checking my tire monitors and did make it to Tucson with no problems.
Curly
That is purely a CYA statement on their part. Example, some may be right on the edge of having enough capacity on a 65psi "D" rated tire. It would be stupid to run 80psi stepping up to "E" If the tires weight dictates 65. GY Tech will tell you to use the weight/inflation chart when up sizing load range and add 5psi to what the chart says.
Example would need 70psi. Per GY Tech running too much air will give you less stopping, rougher ride and more tire wear.
To the nay sayers that I am sure will comment WHY do every tire made have a load/inflation chart if it should not be used?
Curly
