Cummins12V98
Mar 08, 2015Explorer III
larry barnhart wrote:
Our 2wd truck came with D load tires and a 65 lb max air pressure. I wanted E tires so why go back to a D tire load range?
Nice new truck you have.
chevman
Do you run 80 in front also?
Your E tires at 65psi are a much stronger more stable tire than the D's at 65.
Weight inflation charts are there for a reason. Your braking is reduced with your tires at 80psi.
Your rig Larry just something to think about!
About Fifth Wheel Group
