nsmilligan's avatar
nsmilligan
5th wheel wiring
My rig has a 7 pin rv connector in the box, the male connector on the in box harness has corroded pins and lost my running light power in both sockets (bumper and box). Anybody know of a replacement MALE socket that could be spliced onto the harness? Found a number of female socket splice kits, but can't locate a male on
    If I understand you correctly you have a 7 pin plug inside the bed, and that plug as well as the bumper mounted one have lost running light power. I would check the T connector that was added to the back of the bumper plug to run the wires up to the bed mounted plug.
    Gary
  • RoyB wrote:
    When it comes to the safety features I always like to replace with new items rather than to try to save a buck or two 'jerry rigging' something in place to fix things... Just me haha...
    Over the years I have replaced both ends many times, mostly on things the lights must work. When done, tested, everything works pull the cover back off, fill the camp with silicone Form-a-gasket, put it back together, and wipe off the excess. Takes a long time for it to totally dry, but you can use it while it dries. But the thing is sealed just as good as the factory molded.
  • RoyB's avatar
    RoyB
    Explorer III
    ETRAILER.com has a large supply of all different things for RV Trailers... They also have a great section on trailer wiring...
    I'm sure you can find what you need from their on-line site..
    Great folks to deal with. I have ordered things from them many times over the years...
    I also order a lot of items for my RV trailer from AMAZON...
    Roy Ken
