rhagfo
Sep 14, 2020Explorer III
handsome51 wrote:
Their is a lot of things a person can do to his truck to make it do what he wants it to. Even though the sticker in the door saids it won't. I have a 2006 carriage 5th wheel I bought new. It is 35ft 11in long. On a truck scale fully loaded it weighs a little over 14,700lbs.Of that, the hitch weight is a little over 3,100 lbs. That leaves 11,600 lbs on the tires.
I pull it with a 2001 ford F250 4x4 extended cab, 8ft bed with a 7.3 diesel, 3:73 rear end. The only difference between it and a F350 SRW is the suspension. I put Helwing helper springs on the rear and heavy duty shocks on the truck. I have a 25K airsafe hitch in the bed. A 37 gallon fuel tank between the tailgate and 5th wheel hitch. And a generator between the 5th wheel hitch and the cab. When the truck is hitched up, and you look at the side of the truck. It is still sitting up just a little in the rear. The truck pulls my 5th wheel great. And the first time we made a trip. The wife said you don't even know the 5th wheel is back their. And when we get to where we are going nothing moves in the 5th wheel. No plates, bowls etc. And that includes at the back of the 5th wheel. Only time something might move is if you have to slam on the brakes. The air hitch is not cheap. But it keeps the 5th wheel out of a bind and from jerking you around in the truck. Even though the sticker in the door said the truck would not handle it . I made it to where it will handle more than a F350 single wheel will. So if you know what to do ,sometimes you can make what you have work.
Yep, you sure can but nothing you do/add changeS the GVWR or GAWR. Get in a crash, and the other driver gets a good lawyer you could see your life changed!
I didn’t need any extra springs on the 2001 Ram 2500, but towing at 1,700# over my GVWR, would open me up for a lawsuit. So now have peace of mind.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
