Gjac wrote:
Lantley wrote:
jffnkrn wrote:
Jay 58,
just curious as to what made you decide on going 5th wheel as we had been contemplating going motor home? If you care to share
While I consider a 5th wheel to be more work and less convenient than a motorhome. A 5th wheel provides equal amounts of space to a class A and cost a lot less. A 5th wheels gives you more bang for the buck.
The downside is 5'er is not as user friendly as a motorhome.
I have a Class A now and was wondering about this very issue. How much more work is it to set up a 5th wheel? Is leveling a chore? Is a 5th wheel still cheaper if you have to buy a new truck to tow it? One distinct advantage I see is if you get a small enough 5th wheel(28 ft or less) that can be towed with a SRW truck you can always use it for a second vehicle.
Well, it seems like most Class A motorhomes are towing a car to drive around when parked, so you're looking at two vehicles anyway...much of the time anyway.
As far as leveling, it's definitely not going to be as quick as a 6-point or 4 point leveling system. But it doesn't really take that long. I pull into the spot I'm going park, if not level side-to-sied, then I put down a block or two, then pull on to them and chock the wheels. Drop the front stabilizers, unhook the truck and level front-to-back. Hooking up power, water, and sewer is basically the same.
