Searching_Ut
Jul 25, 2017Explorer
You can download the manual if you don't have a copy. It has the instructions on how to re-calibrate the "level" set point. I check mine with a level once or twice a year and re-calibrate the system if required.
Also, mine has a tendency to start making a "popping" noise during the heating and cooling of the day after it has been parked for awhile. There is a service bulletin you can find on the net that tells you how to add a quart or two of anti Stiction fluid to help with the problem should you encounter it. I made a couple measurements on my struts and was somewhat surprised to see that normal expansion and contraction on days with wide temperature swings between night and day could be almost a half inch.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 23, 2026
