Searching_Ut
Jul 27, 2017Explorer
thirtydaZe wrote:
There isnt any harm in just raising the front a bit after auto leveling is there? We've moved on to our final destination, and while the nose down condition isnt really noticable, it's still present.
Only reason for even wanting to mess with it is the shower water wont fully drain.
I do it all the time with mine. Sometimes it's so far off level to start that the auto level won't initiate so you have to just put blocks under the low side jacks and manually level.
When you do make adjustments, make sure you use the manual controls on the leveling system rather than the switch for the front jacks if you have a separate switch. That way the 4 forward jacks work together to raise the front rather than just the front landing gear jacks.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 19, 2026
