TiredMom57 wrote:
We have a Dometic A/C that's stalling out. It stalls anywhere from 1-5 seconds then comes back on. Sometimes it comes back on blowing stronger than it did before it stalled. Anyone have this problem or can give advice to a solution? We had a tech come out and he had to change the control board b/c the wires and wire caps were burned!!
Thanks!
Are you running the fan in Auto?
I have the Single Zone LCD Thermostat, when the Fan is in AUTO as it approaches the correct temp, the fan will shut off for a few seconds to switches to low then start back up, the compressor keeps running during this swap over. Sometimes it does this again to high. I run the Fan in Hi or Low until the temp is stabil in the unit, then Auto works fine.
here is the info from the manual on the "special feature"
Special Features
Auto Fan
When auto fan is selected the fan speed will vary depending on the
difference between the temperature set-point and the room temperature.
In auto fan the compressor and fan cycle On and Off with the
thermostat.
When the difference is:
>5º The fan operates on HIGH
<4º The fan operates on LOW
