pianotuna wrote:
More effective at low temperatures maybe. More efficient, no.
There are ways to heat 100% electrically without the cheap heat system while preventing plumbing freeze up while NOT disabling the propane furnace. For me, that is a deal breaker on cheap heat. They could fix it, if they wished, but they don't.
I don't understand what you're saying. The CheapHeat system in our 5th wheel doesn't disable the propane furnace. Ours has a rocker switch in the control cabinet with the thermostat that allows the user to select either "Electric" or "Propane" mode for the furnace. I've operated the furnace in both modes.
Rusty
