Hi Rusty,
If you are NOT in the RV and it is cold (and I mean in the -30 range) and the power goes off the cheap heat system does not fail over to the propane furnace. That is a deal breaker for me. They could solve that with a relay but they choose to not do so.
In addition you can not use both the propane furnace and electric heat at the same time via cheap heat.
I do heat 100% electrically but my propane furnace is ready to jump in should the power cord be knocked out, or the campground power fail. I have 3 shore power cords, the OEM 30 amp, a 20 amp, and a 15 amp. Peak load is 7000 watts.
Last March when I returned to the frozen north I got my RV out of storage, turned on all my electric heat, and ran the propane furnace. It was all warmed up within an hour.
RustyJC wrote:
pianotuna wrote:
There are ways to heat 100% electrically without the cheap heat system while preventing plumbing freeze up while NOT disabling the propane furnace.
I don't understand what you're saying. The CheapHeat system in our 5th wheel doesn't disable the propane furnace. Ours has a rocker switch in the control cabinet with the thermostat that allows the user to select either "Electric" or "Propane" mode for the furnace. I've operated the furnace in both modes.
Rusty
