twinstick's avatar
twinstick
Adding 2nd air, converting from 30 amp to 50 amp
I've currently got a 2013 keystone Laredo 279sre. I really like this camper, I plan to keep it, and getting a new one is not in the cards right now. It is currently a 30amp service.
My problem is, in the summertime in the South, it gets hot. The single 15k air unit will run from 7am-10pm sometimes without stopping. It will only cool too about 82 or so in the heat of the day.
With all of this said, I want to add an air unit up front and convert to 50amp. The converting to 50amp shouldn't be too much of a problem. My dad is an electrician, and a good friend is. Looks like I need a new plug, wire, new power distribution/converter, and new power cord.
The problem is running power from the power distribution to the front air unit. My questions come in with how hard it is to run wires in the ceiling, and who has pulled down ceiling panels and trim and how much is involved with that. Thanks for all the help, -Clayton.
  • Thanks for all the replies. I've read about people running the second air directly to the pedestal. While this absolutely is the easiest, I don't really want to do this option and would rather convert to 50amp. I will check to see if it is pre wired, but I'm 99% sure it isn't, and don't really see why it would be with 30amp. I think I will learn a little more by pull pieces out of the ceiling. Is that thought to be easier than to the front of the camper, underneath and back up to the power distribution?
  • I suppose some have managed to run two AC's on 30A but when ever I've run even one the plug got warm.
    Adding a seperate plug for the 20A outlets at parks seems like a good idea on the surface but I've always found them to be loose and worn out at any CG's I've tried to use them.
    Your on the right track going to 50A in my opinion. It's the one way to not have to worry about power when running two or more AC's.
    My current rig has 50A and I would never go back.
  • yillb wrote:
    Ehh... Your trailer is 2nd AC prepped, considerably different than what he said. having prep for a 2nd AC without a 50AMP service is mostly useless, and would only have been done either by mistake, or custom order. The dealerships are not going to order rigs like this, they don't sell, and there is a reason for it.
    I guess you will tell me next my 04 pace arrow was wrong from the factory with 2 a/c's and 30 amp service.
  • Bird Freak wrote:
    This is not true in all cases. I have a 30 amp unit and my bedroom vent is prewired for a/c.
  • rhagfo wrote:
    midnightsadie wrote:
    take out the air vent some are pre wired.
    If pre-wired the trailer would have a 50 amp service. To get wire from the distribution to the AC location onec you find a way to the ceiling, i would pull the trim from all the roof vents between where you get to the ceiling and the AC location, and snake it through. You might get a fiberglass snaking rod, much easier then working the wire through itself.
  • rhagfo's avatar
    rhagfo
    Explorer III
  • I'm actually on the verge of adding a third air to a 50 amp motorhome But I will wire it so that it can use internal or external power. I plan on having a corded end to the unit itself and then have two separate junctions with outlets, one tied into the extra circuit breaker on the motorhome panel and the other ready to be plugged into the Park pedestal if a spare 20amp outlet is available.
    From everything I've read here, the easiest way to do it would be to add the 2nd unit and use a separate 20a cord to plug into the pedestal. The cleanest ones I've see use a separate junction box in the exterior with a male plug recessed in, then a short extension cord direct to a 20a plug on the pedestal. I've =seen= one where a guy just had a cord direct from the A/C unit on the roof and plugged into the pedestal. Said he just coiled it up around the box on the roof when he moved, and zip-tied it to keep it from uncoiling. :B
    Lyle
